Perspex sheet
keith dublin
Looking for a sheet with a bend on the top to hang in front of my tv the lads are swinging clubs and kicking ball in the house so was gonna do this till they are a bit older
Anyone on here know of a place
Cheers
Keith
B&Q might have perspex sheets not sure if they have bends but you couldn put a bend in it,
There's probably a simple way to do it,
you could try stretching thought an old brake cable from one of the bikes, heat it up then lay the sheet across where you need the bend :dontknow:
If you can get some Keith I can bend it in work. We've a heated wire element for heat bending Perspex and plastics. It's expensive stuff though.
as above b&q will have some :thumbsup: make sure to mind it when bring it home as it will scrape easy enough :thumbsup:
[quote author=Tommy 555 link=topic=39158.msg447355#msg447355 date=1379274864]
just buy some rope and tie the chaps up for a few years until there 14 or 15 . cheap way out
And change your name to Fritzel. Lol
[quote author=tractorman link=topic=39158.msg447420#msg447420 date=1379348793]
i take it you never met tommy west
