Prosport Oil pressure Gauge and boost gauge(BAR)
Altezza-Dan
Edit: only selling oil pressure gauge now, tested fitted the oil gauge and its too deep to fit in the cubby i wanted to put it in. All thats needed to fit this is to screw sender into oil galley plug on top of block and run wires into the gauge. if you dont have the space, you can mount the sender remotely, using a stainless steel oil hose and oil galley adapter(Subaru)
More details on gauge here:
http://www.lbperformance.com/index.php?main_page=product_info&cPath=79_98&products_id=1222&zenid=m5niabo981cdhatu7b8paca8q5
Illumination can be changed depending on how you wire it. I went for white with amber needle, oil pressure gauge would be same as this:
Test fitted never actualy wired up
Boost gauge fitted and used for a month or so taken back out of the car
http://www.lbperformance.com/index.php?main_page=product_info&cPath=79_97&products_id=1230&zenid=gskm6iovfupa8vlv84jcqb2m70
Both for 50 euro, bargin at that price
Re: Prosport Boost Gauge
bump, also got a new Prosport oil pressure gauge with sender unit, only thing needed is the sandwich plate for oil filter which you could pick up locally in any motor factors
Can do them both for 75 euro to ISDC member :subaru:
links to gauges here:
http://www.lbperformance.com/index.php?main_page=product_info&cPath=79_98&products_id=1220&zenid=ej5qm7dj80qpk93f8hslifp8k0
http://www.lbperformance.com/index.php?main_page=product_info&cPath=79_98&products_id=1222&zenid=rqt945onig0auglb04oi3reep3
Can get a better price than that lads!
Did you get a replacement stepper motor boost gauge Dan? I killed my swoosh sender unit by letting it get wet. Interested to see what urs is like
[quote author=dossie01 link=topic=26559.msg313809#msg313809 date=1285064801]
i Havent ordered up new ones yet. was going to wait until i sold these. boost gauge is mechanical, oil pressure gauge is electrical
Re: Prosport Oil pressure Gauge
[quote author=sliweczka link=topic=26559.msg318027#msg318027 date=1287243466]
It's 52 Or 60mm?
52mm
Just to clarify Dan-do these light up white with red needle and are they smoked when off? Also do they "swoosh" on startup? Will take both if yes to all the above.
[quote author=B4 soon link=topic=26559.msg320911#msg320911 date=1288665108]
yes, white text with red needle, smoked when off. not sure about swoosh on startup, i think the needle may just rise and drop again to standard presssure
B4 soon... Google the prosport gauges and you'll get an idea of what they do on start up.
Thanks Andy. Sorry bout the questions but I wanna be sure i get the right ones,Did you try to fit them in a single din slot Dan? Thats where I want them-dont like pillar pods.
[quote author=B4 soon link=topic=26559.msg321338#msg321338 date=1288869052]
they are 52mm, i had them sitting in my centre cubby pod, its larger than din size though . u can buy steering column pods for them i think, only size you would fit in single din is 40mm or smaller
I'll take them anyway Dan-Alantul can fabricate a holder-let me know how you want payment and ill get you sorted
Good man I'm actually away in California until next sat so can meet up next weekend if your around.
