BazGF8 OG Wagan ISDC Club Member Apr 30, 2013 #1 As title. Pair of rear brembo with discs and pads. €250 Paint perfect
OP OP BazGF8 OG Wagan ISDC Club Member Apr 30, 2013 #3 Re: Re: Rear gold brembos [quote author=STi Brian link=topic=37815.msg1#msg1 date=1367330929] You change your mind again? [/quote] No not at all these are another pair. You interested?
STiBrian Octane Boostaholics Apr 30, 2013 #4 No sorry was just curious had you changed plans again as I saw the wheels still for sale.
OP OP BazGF8 OG Wagan ISDC Club Member Apr 30, 2013 #5 Re: Re: May 2006 - Brian's Impreza 22B STi I have a full set of brembos on my car I just bought these as well. Pity the 16's don't fit over them
Altezza-Dan Octane Boostaholics Apr 30, 2013 #6 What size discs are with them? I'll need to check out adapter brackets for mine to make them work
N nivek4209 Petrolheads Apr 30, 2013 #7 discs will be 316 mm With 190 mm brake drum for hand brake I have adapter brackets for fitting to an impreza
OP OP BazGF8 OG Wagan ISDC Club Member May 1, 2013 #8 As Kev said just standard 316 mm with 190 mm handbrake you will need the god speed discs with the 170mm insert
N nivek4209 Petrolheads May 1, 2013 #9 Or the fat brake shoes or do what I did and fit a liner to the Std disc
