Removing Defi Sensors
Owain
I'm going about removing all the random defi wiring from the wrx as it came with a defi controller and sensors but no gauges, and I've no intention of spending 600 quid on defi gauges. I've traced all the wiring inside which has 3 wires running into the engine bay through the firewall which I assume is the boost, oil pressure and oil temp sensor signal wires. There is a small (boost?) signal box with a single wire going in along with a vacuum line. I'm assuming this can be safely removed without any issue?
The thing I'm worried about is the oil pressure and (temp) sensor. I've read the stock oil pressure sensor throws the light at around 5psi at which point it's too late anyway. Is that true? This would be the sensor under the alternator? Can I remove and plug the hole?
There is another sensor at the back just under the turbo/intercooler join. I'm guessing this is taken as oil temp? Again can this be removed and blanked off?
None of these wires run anywhere but to the defi "harness".
View attachment 109401View attachment 109402View attachment 109403
Hi
Yes can refit the factory sensor. And depending where the temp was installed. Possibly at cy3 then can refit the allen key blanker plug. Would have all there. Carefull when pulling through wires at bulkhead. As can get caught and damage the plug.
Where are you based.
