Gents. I have finally gathered all the bits for my Brembo upgrade.I should be fitting them this weekend. I just had a thought. Will my space saver wheel fit over the bigger brakes and discs or do I need a diffrent one?
Cheers.
Hi
If you are only fitting the Brembos to the front , you can keep your original space saver but if you have a front puncture , you'll have to fit a rear wheel on the front , and put the space saver on the rear
Cheers Ian
