Specific pad part number for Subaru 4 pots.
[quote author=midlandbe5 link=topic=39533.msg451415#msg451415 date=1383227490]
EBC Brakes Yellowstuff Pads - Front (DP41200R)
Great pad
ebc :puke3: have never used the yellow stuff to be fair so maybe there way better than the rest of the range :thumbsup:
well their bluestuff didnt hold up very well around mondello and they are a more track orientated pad than the yellow stuff, yellowstuff might be not so good for the heavier legacy, i would go with ferrodo ds2500's. When did you change to the four pots? small disks too unless you got some custom brackets to make them fit the larger 316mm discs
if u have 4 pots and 294mm 4pot discs, its no upgrade form the standard floating 2 pots with 316mm discs, these legacys need a good big set of discs on the front of them :)
Anyone that reckon yellow stuff are bad , you are using the brakes too much and over heating them
