sti turbo vf22
W
weevan
Guest
hi have a vf22 for sale no play in shaft looking 330euro
IHI-VF22 Turbocharger Assy.
Originally used on Ver.3 JDM WRX & WRX RA models. This is the largest of the VF series turbos and is recommended for use on cars with significant modifications and where flow capacity is more important then response time. Ball bearing center section with large P20 turbine housing. Turbo will start to come on boost at 3300 rpm, however is capable of running up to 25 psi @7000 rpm
