Codders
Member Number 162Full ISDC Members 2015
Hi guys
I replaced the split turbo inlet pipe which I thought was causing the issue - but it seems not resolved it completely.
only when the engine is HOT - there is slight hesitation at 3k rpm, also when cruising on motorway around steady 3-4k rpm you can feel like the car is slowing down and pulling away again in regular intervals.
No problems whatsoever on boost.
I've already replaced the spark plugs, checked all the connections on the piping (had the manifold out recently so basically all the pipework has been reconnected) and issue is still there.
As I said only when hot and off the boost, at exactly 3000 rpm.
Any ideas?
Any ideas?
