Hi Colm yes seen that but its a different model to mine, radio has been of a while going back to the time i blew the main fuse. Been looking on google a while for the fuse but google isnt showing me fuse location and cant seem to find it in the manual and losing patience lolNot sure Aido but maybe like the back of this one (different model but could be same)
Has it only hapened ?
the radio fuse will be behind small pocket right side of dash ,pocket should display which fuse in car it is , make sure youre reading right way up bye knowing which amp fuse is top on picture vs looking in to fuses
Yes that fuse is ok thanksInterior fuse box and diagram by your right knee
No worries Gary thanksCan't remember aido I put that radio in I thought there was a small fuse in the back of it pull it out and check if you had another head unit to check to see if the radio is broken or get a volt meter and check pins should have 12 volts in plug off car side
Its been of a while Joe could be when I blew the main fuseDid it just stop working or didn’t come on when you started the car
Yes Colm looks like I have no choice but open it up to have a look I guess thanks mateInternal fuse id say aido bunt may be dead but maybe there is a internal fuse
Thanks Joe your a legend mate radio back on thanks again guys you got me out of another hole lolLook closely at the radio . Take out the plug the fuse is under it . Purple 1
