anto787
Member
Hi All,
Modified ej25 for sale.
It has a steel crank and rods with forged pistons. The short engine was built by cosworth. It has a Cosworth branded sump baffle plate, Cosworth high pressure oil pump & HKS kevlar belt.
The heads are non AVCS Version 3 heads from a GC8 and they have had a lot of port work done and they are fitted with HKS cams.
They have RCM bronze inlet and exhaust valve guides. There is also a Garett GT30 turbo in perfect condition on the engine. It has 850cc injectors and the parallel fuel rails fitted.
Build receipt is attached in the photos below.
Asking price for the engine €6,000
