Funny that I was looking at the edfc active pro, but my teins on the soft settings seem way to hard, again they just need a rebuild I cant base anything on them.
Ive set them on full soft just to see if I could get some feel for them but they were no different
I'm going to raise them and check the preload. I might have a crack at building them, i might be able to get seals at a hydraulic ram place
Get a set if bc and spec them with 4 and 3 spring rate like I did savage on the road ????
Is it the BR series your running?
Where did your find was the best priced place to get them?
Obviously being 2nd hand all bets are off...
You will just have to weight up the cost against the risk.
I'd probably take a chance at 150-200 for a full fresh dry looking set... but it's a buying a pig in a bag scenario..
They are an old car at this stage, and only hope it had an sti dampener replacement done was when the car was back in Japan.
