USED:
Will fit 775 & 1155 sockets.
Comes with tubing.
Rads are in perfect conditions with no leaks.
Barbs are tested no leaks.
I had my Core 2 Duo 2.66ghz OC's at 3.599Mhz (shown in pic below)
€130 + €25 P&P due to heavy weight
Total: €155
Specs:
2x watercooling RAM covers (they are €25 each alone)
Water Block:
Application: Intel LGA775, Intel P4 478 pin, AMD K7, AMD K8, AMD Sempron
Water block dimensions: 60 x 78 x 23.5mm
Construction: Copper / Acrylic
Single three pin connector for blue LED in block lid
Water Pump:
Water pump dimensions: 75 x 70 x 75mm
Rated voltage: 12v
Pump rate: 400 lph
Sound level: 16 dBA
Single four pin Molex power connector
Internal blue LED in pump housing
120 mm Radiator / Fan:
Dimensions: 122 x 35 x 166mm
Construction: Aluminum / ABS Plastic
Fan size: 120 x 120 x 35mm
Fan speed: Variable rate 1300 ~ 2400 RPM
Sound level: 16 ~ 30 dBA
Air volume: 38.6 ~ 93.7 CFM
Single four-pin Molex power connector
240 mm Radiator / Fan:
Dimensions: 272 x 35 x 120mm
Fan size: 120 x 120 x 35mm (two)
Fan speed: Variable rate 1300 RPM
Sound level: 26 dBA
Air volume: 54.4 CFM
Comes with tubing.
Total: €155
Specs:
Water Block:
Water Pump:
Rated voltage: 12v
Pump rate: 400 lph
Sound level: 16 dBA
Sound level: 26 dBA
