toyota fuel problems
scoobysub
05 1.4 d4d corolla van 40k on it and never drove hard .it keeps cutting out it mightn't happen for a week and it could happen 4 or 5 times in one day have to get out and pump it 8 or 10 presses on the fuel pump , its on top of the filter .now the thing is it's serviced reguraly , so all the filters were changed again when it happened but there were spotless when i took them off .so brought it to the main toyota dealer where it was bought.dropped it off to them they changed the filters and and checked it on the computer and it showed up no fault so the said to see how it got on . the next day it stopped again rang them up they said there was nothing they could do that no fault came up on the computer and that there was nothing they could .so anyone any ideas what wrong with it
Re: toyota fuel problems
could be drawing air from somewhere!!!!
had this kinda problem on a 07 fiesta diesel lastweek....
the customer would open bonnet after cutting out and use hand primer!!!
i found a leak under the airbox in a clear fuel pipe....
was on a low pressure pipe so very little diesel was leaking from it!!!!
:dontknow: :dontknow:
could be a fuel pressure regulator problem!!!!
:ponder2: :ponder2:
thanks markobucko going looking at it this evening and will check all pipes again thanks again
