I used a product called socomore socopac 65h its used in the aviation game I found it to be quite good but it's too early to tell as I havnt had it on the road yetWhat product did you use and would you reccomend it thanks
She is a fresh import but still did a wash dry and whole underbody was oiled, inside pockets sills and front and rear legs [emoji106][emoji106] Looks like a clear waxoil applied .
It?s all about the condition of the car or the surface it?s going on . No product stops rot or rust they just slow it down or cover it . Condition is everything but the products certainly help [emoji106][emoji106] Hope you sprayed in the cills [emoji106]
Spray job, its a clear but golden finish, I use the car daily and i plan on stripping and painting everything over the winter the beauty of the wax oil is that it can be washed off with hot water when i need to work on it and it doesn't look like your trying to hide something [emoji102]Good job did you spray it on or brush it on and what is the final finish as in is it a clear liquid I have always passed by it but never used it. My father used to put that stuff on all his old yokes just remember the can knocking around the garage just curious
