I had one of them ssqv on my old wrx have to say it got a bit annoyin, but think ya can adjust them can't ya.. I just have a wastegate on mine now and it sounds cool not too loud.
i like that one not really it to the whole psssst or whoooosh thing
Put a blanking plate where you dump valve used to be and you will get that sound, dont think the turbo would last too long though. I would stick with an original recirc dump valve unless you are highly modified, as dumping the air can confuse the ecu, and it will under fuel because it thinks there is very little air in the mixture.
aye i wasnt planning on fitting one ..on the b4 the air is used to spool up the second turbo(complex piping system don't ask me) so fitting just creates a larger VOD..apparently..so they say
[quote author=Scruff link=topic=4302.msg45562#msg45562 date=1194986907]
[quote author=Dagnut link=topic=4302.msg45559#msg45559 date=1194985954]
how do you get that chattery one sort of like this
Alan
Ya I had a blitz one on my car when I got it and my local subaru gargae said to take it of as it was a non recirculating one an that it not a good idea as said above
I got a new dump valve on the type-r. Its the latest HKS one, it does a load of "chatter", and sounds fairly cool. If you give Dave Leggy a shout he will be able to get you one
[quote author=Michael Spec C link=topic=4302.msg45582#msg45582 date=1194989182]
Hello Paul,
If you want to hear it, give me a shout
Cheers,
Michael
Sounds that way with the FMIC fitted......... Sound like normal one in standard position...
