What size Brakes & Pads for 2002 JDM WRX ?
ondafly
As the title says - what size Brakes and Pads do I need for a 2002 JDM WRX ? Current ones are badly needing to be changed :police:
mate they should be standard four pots up front and two pots rear which is the same brake set up as the irish wrx so any good motor factors should have them also try the traders on here couture are decently priced on pads but they all will give you a good price
Hi Lads - having a bit of bother getting these discs - I went to motorfactors, and they said according to their system, the discs are 277mm, but should they not be 298mm ? I've taken a snap of the discs on front, if anyone can advise ?
ok lads - went out and took the wheel off, was just being lazy earlier. I can confirm they are 298mm
