[quote author=thedoc link=topic=2658.msg25261#msg25261 date=1182431383]
I called a number of main dealers on this and they were all using 10W40 various brands Maxol,Shell etc. I personally feel if this is what they use on cars under warranty then it must be up to the job. I've been using 1040 for three years without issue and dont see the need to pay three times the price for something thats not required, surely Subaru would'nt put their ass on the line by using inadequate oil.
It is up to the job in most cases and with standard cars. Its not inadequate either its just not one of the better oils. The 10-40 bit is fine, the reason I wouldent use what they say is because the low quaity of semi syn oil, It breaks down into hard particles, Which will have a bad effect on big ends and mains and most likely cause failures. On cars that are not standard Semi cant take the temps.
On another note which Im not sure about but did Suabru not change there oil rating for newage cars to 5w30 from 10 40 that was in the GC8 book ? which is very thin . Eric / Doc did they ask you what model impreza it was. Can someone with a newage car check there owners manuel or service book and see what grade Oil it sais to use. Might be from 03 on ?
Damo
