Wrx Sti version 2 build
Tonzboher
Iam doing up a version 2 sti at the moment, anyone have any ideas as to what to put in suspension wise to make it handle half decent?
If the factory dampers are in good order with no leaks etc.. Then a set of Eibach on those is a fine job for cheap enough outlay imo.
Is it worth putting adjustables in the car? What about upgrading bottoms arms and bushings?
Cool be a good read man. What kinda condition is it in now?
saw that car on donedeal a few times - there was posts on here about it
are you sure its a version 2? the reg said it was a 98 uk turbo model
best of luck
as dave daid the factory red shocks are hard beat
your thinkin of diff car
this car above is on a uk plate
No this ones a proper wrx sti, it's in good condition, have a few things I want to do to it, anyone know if it's worth putting in rally group n bottom arms and bushings all round?
I posted not so long ago about suspension setup for my type r.
BC coilovers were recommended on the 4/3 long damper setup, not the standard 5/3 setup.
Scoobyworld seem to be the cheapest and it takes 2 to 3 weeks for them to get in the 4/3 setup.
Few members on here said there could for soaking up the bumps on our irish roads and are similar to the std stuff.
I'll be ordering once I have the funds, not much change from 1k.
