I acnnot find anywhere that can change the language. I don't think it is an option on this model. Jap market only. Has to be a way to turn off the sat nav voice.
Did u try to disconnect battery and drain power from system yet? May help with jap lady I guess. Not sure.
You should be able to find manual for radio online. I doubt it will be in English but at least will have some pics and point by point instructions so my figure out what to do.
You won't able to change language in radio from Jap market ....ever You my get CD with maps from manufacturer of head unit but cheaper would be to get new one Just throw this thing out and het aftermarket one. Less hassle
hey. To jump on the back of this thread i got the bluetooth working on the radio and delighted with it. I do however have quite an annoying issue. When i was figuring the radio out i managed to somehow turn on a destination on the sat nav and a lovely japanese girl keeps taking over the radio telling me i am going the wrong direction. It is quite annoying at this stage and i cannot turn it off. I have tried the google translate app but with no luck. Does anyone here speak japanese who may be able to help out? other than that possibly disconnecting the battery may reset it? I assume that would not affect the remap done by AP performance. I believe aonghus said this would not affect his map.
Thanks for the help.
Hi, did you try the google translate app for your phone?
There is a camera mode where it can translate in real time for you, its pretty cool. Its not perfect english but you get the idea. I found it helpful adjusting some settings in my JDM Carozzeria unit, no more annoying beep every time adjusting the volume or pressing a button. cheers
hi Jarocki im in the hunt for a double din conversion the one without the dual climate control, for my legacy my car has the kenwood unit and a panasonic sat nav so thank god i dont have the same things happening to my radio only problem is i have two stations rte and god fm im going mental , have you tried to disconnect the gps it is located in front of your rear view mirror the little black box thingy , worth a shot
I know a bit of Japanese, here are some helpful translations:
English to Japanese with the voice command/pronunciation
Disc ................ディスク "Disku"
Card (SD).............カード "Ka-do"
Japanese..............日本語 "Nihongo"
English...............英語 "Ei-go"
off...................オフ "Offu"
cancel................キャンセル "kee-anceru"
accept/ok/yes.........OK/はい "Okay/Hai"
install...............インストール "instaa-ru"
Navigation............ナビ "Na-bi"
language..............言語/ランゲージ "Gengo/Lan-ga-ji"
Next..................次 "tsugi"
Back..................バック "backu"
Time..................時間 "Jikan"
Timezone..............時間帯 "Jikantai"
Today.................今日 "Kyou"
car...................車/カー "kuruma/kaa"
insert................挟み込む "Hasami komu"
input.................入力/インプット "Nyūryoku/inputo"
Turn off..............電源を切る "Dengen wo kiru"
"Insert Disc please" ....ディスクを挿入してください "Disuku wo sonyou-shite kudasai"
And careful mixing up these two:
Chicken...............チカン "Chikan"
This one is tasty.....これはおいしいです "kore wa oishii desu"
Groping...............チカン "Chikan"
This one is a crime...犯罪です "kore wa Hanzai Desu"
