02 - WRX suspension
Zheiko
Hey,
since I have upgraded to BC coilovers, I was left with full shocks+springs all car round. I have two front shocks that have between 10-15k km on them, and then rear, where the mileage is unknown.
I am selling them either as a lot(including standard springs) for 150e
or individually:
front for 100,
rear for the price of springs only(shocks are still fine however but a bit aged, about three years, no leakage though) 50e
I just missed those. Tom lives around the corner from me. How did the car sit on your standard suspension.
this is with stock springs
and the bellow is with BC coils
I live north part of Dublin. If you have way around. Or, if you want I can meet you half way - Naas?
weekdays anytime after 7pm, but needs travel, so it will take me maybe 1h to get to Naas
hey, Fronts are defo not knocking, one of rear ones were squeaky, but I believe that with little grease it will be fine - hence rear ones go only for 50.
Gimmie call at O86O4525(nine)6
Are you scrubbing the rear arch? They have quite a wide lip, although the coilovers probably are hard enough to stop that much travel.
when rear is not loaded, I dont. Yesterday however, I had filled my trunk with Airsoft gear of 3 ppl(rougly 50kg on its own) and about 80kg passenger there, and I did some rubbing on roundabouts. But nothing that couldnt be solved by stiffening the coils even more. They are currently set as two clicks from the softest settings, so there is deffo some more play there.
