B bassdrive New member Mar 24, 2014 #1 Hi, The rear 12v power outlet doesn't seem to be working in 08 Impreza hatchback. I`ve checked the fuse, but its ok. Any ideas what to check next?
scoobysub Well-known member ISDC Club Member Mar 24, 2014 #2 is it in the boot or back seat as i know some of the outlets were just blanks with the hole there
OP OP B bassdrive New member Mar 24, 2014 #3 It`s in the armrest storage between drivers and passengers seat.
scoobysub Well-known member ISDC Club Member Mar 24, 2014 #4 well if the fuse is not gone then the problem is at the outlet . remove the handbrake surround and see are the wires out or a clip broken on it but there usually soldered to the base but worth a look
