1997 impreza turbo trouble
ph2010
New member
hi guys can any one help im haveing trouble with my car i think the vacume hoses are in the wrong place on my car as the turbo is not working and car keeps reving hi then cutting out can any one help i need to know were all the vacume hoses go pics would be best its doing my nut :hammerhead:
ah i see, i was out looking at mine but mine is not standard set up as ive dump valve, boost guages and boost controller, ive 3 ports on my inlet manifold how many have u
Well il tell u some of mine and hopefully someone else will help u with the rest, the 2 on the inlet on the p/s one is going to the dump valve and the other goes under the inlet to a little green plastic port on the fuel rail, on the other side of the inlet that one goes to a brown solenoid (located on the d/s inner wing/ under the shock mount) the others for the turbo and actuator i cant help u as ive a after market boost controller, hope this helps
Thanks I will try this and if there are any others I will get pictures and post them up for more advice.
