2.35 Impreza for Sale GT35R Turbo PPG Gear Kit High Spec May Break
R
Renno555
Guest
Now for Sale at €15k. Or it may be stripped and parts sold separtley :thumbsup:
Please Contact me on 0879353088 or PM me for any further details. It started with 1995 4 door Impreza that had everything stripped from the car to leave an empty shell ready to build up. Version 6 front end conversion ( bumpers lights and bonnet ) went off to the spray shop to get a paint job. It was a 4 door Impreza but has been changed into a 2 door. Can be sold with the full interier if needs be.
Every gasket and seal has been replaced with brand new items.
The price is 15k which is very good if you consider how much the 2.35 Litre engine and PPG gearbox are alone.
SPECIFICATION
2.35 Bottom End
Closed Deck Block Bored + Honed with piston squirters relinered and modified to take the Phase 2 Crank.
ENGINE79mm Stroke Crankshaft
Wiseco Stroker Pistons.
Custom Crower Con-rods.
ACL Race Series Bearings.
Custom Cometic Head Gaskets.
ARP Head Stud Kit.
Modified Oil Pump.
Baffled Sump.
Oil Catch Tank.
Ported + Polished Ver 6 STi Heads.
Supertech One Piece Inlet Valves.
Supertech Inconel Exhaust Valves.
Custom Reversed Inlet Manifold.
Uprated Power Enterprise Kevlar Timing Belt.
Racing 8 Spark Plugs.
Bosch Air Temp Sensor.
Oil Cooler Kit.
HKS Dumpvalve.
Tuffnol Inlet Manifold Spacers.
Induction / Breathing / Turbo
Lateral Front Mount Intercooler / Radiator Kit.
Custom Intercooler Pipe work.
GT35R Turbocharger with .82 housing.
Tial 44mm External Wastegate with Screamer Pipe.
Rotated Downpipe + Upipe.
3” Exhaust System with DEI heat Wrap.
GT Spec Headers + Uppipe Wrapped.
100mm Spun Aluminium Trumpet + Cone Filter with Samco Intake.
Engine Management
SimTek ECI with Antilag and Launch Control.
3 Port Boost Solonoid.
AEM 3 Bar Map Sensor.
Fuel System
740cc Injectors.
Modified Parallel Fuel Rails.
Fuelab Fuel Pressure Regulator Kit
Bosch Motorsport Fuel pump ( Soon to Be Twin Pump set up )
Goodridge Hosing + Fittings
Drivetrain
5 Speed PPG Straight Cut Gear Kit
Billet Selector Forks
Exedy Hyper Twinplate Clutch & Integral flywheel
Suspension
Tein Flex Coilovers
Whiteline anti roll bars
Whiteline Anti Lift Kit
Brakes and Wheels
AP Racing 6 Pot Calipers + Discs Ferodo DS 2500 Pads
AP Braided Brake Lines
Motul Dot 5.1 Brake Fluid
Ultralite G-Grid Rims
Toyo T1-R Tyres
sti 9029 said:
how much would the discs and pads be and also would i need bigger wheels to fit them in??
Hi mate, The whole break set up will be sold in one lot. Ive no idea what wheels you have or if they would fit behind them im afraid. Best check that with AP first.
PM EMAIL OR RING ME FOR ANY INFO
Damo
