2008 6SPD GEARBOX WITH DCCD, COMES WITH EVERYTHING FOR CLASSIC TRANSPLANT
KENC
2008 6spd gearbox with dccd, comes with everything for classic transplant
Testing the waters here, might sell this from my car.. Gear box is from a 2008 Uk Prodrive Hawkeye with only 8,000 kmls on it, it has DCCD.
I got the Gear box, prop, starter, gear stick and linkages and rear diff from the the 08 car, I got a 6spd flywheel fro Ali Burrows and a new Exedy 6spd clutch kit from Streetperformance,there is only around 100 miles or that on clutch, both box and diff were drained and Millers Lsd and gear oil used, again only 100 miles or so..everything needed to do a transplant into classic..
6spd dccd Gearbox
6spd Diff
6spd Prop
6spd Gear linkage and stick
6spd starter
6spd exedy clutch
6spd flywheel
Plus there are certain bits that had to be sourced from UK to enable transplant, everything will be going together. the amount that i can get will be what dtermine whether i go ahead and do this.. so txt pm or txt me your offers
Hi, how much are you thinking of, my type r does 100 motorway kims a day so could be a worthwhile investment if price is right.
rgds,
John
