[quote author=Keith_SP link=topic=31017.msg358656#msg358656 date=1312129308]
[quote author=KENC link=topic=31017.msg358620#msg358620 date=1312116042]
[quote author=Keith_SP link=topic=31017.msg358611#msg358611 date=1312103069]
[quote author=KENC link=topic=31017.msg358593#msg358593 date=1312069730]
I think there is a difference in the thickness of 6spd and 5pd, effectively if im correct that would drop a 5spd down away from the body of car more than its standard mount
Nope they are the same mounts, for instance the Group N Engine Mount kit that Subaru sell's is the same kit for either a car with 5 speed or 6 speed ;-)
Keith
May have to agree to disagree on that, my 6spd box fowld the body because i used the old 5spd cradle and mount, and 2 ways around this is to bash the rib on tunnel or use the 6spd mount
That is because you used the 5 speed craddle nothing to do with the transmission mount ;-)
Keith
If you wont take my word for it check out STI Prt numbers SPE179 and SPE184 or if you dont beleive them maybe RCM part numbers would help convince you SPE82 and SPE764, it may be only 5mm in difference but there is a difference never the less
