oil change every 8k would be grand, check all the fluid then too.
timing belt at 100K or 5 years if it hasn't been done already
From legacygt.com
7,500 Miles
-Inspect and top off all fluid levels
-Change engine and oil filter
-Inspect starter safety switch
-Test starter safety switch
-Inspect brake line and hoses
-Parking brake check and adjustment
-Inspect power steering rubber hoses
-Inspect exhaust system
-Inflate tires and inspect wheels
-Rotate tires
-Check rear axle oil
-Suspension and steering check
-Adjust engine idle speed
-Adjust steering gear play
15,000/45,000**/75,000 Miles
-Change engine oil and filter
-Inspect brake lines and hoses
-Inspect pwer steering rubber hoses
-Rotate tires
-Adjust brake pedal free play
-Adjust clutch pedal free play (if applicable)
-Inspect cruise control linkage and hoses
-Lubricate suspension and steering system
-Lubricate throttle linkage
-Fuel cap, lines, tank, and filler lid inspection
-Clean drums and disk brakes
-Replace air filter
-Check and adjust valve clearance(if applicable)
22,500/37,500/52,500 Miles
-Change oil and filter
-Inspect starter saftey switch
-Inflate tires and exspect wheels
-Rotate tires
30,000/60,000/90,000/120,000 Miles
-Inspect brake lines, hoses, front brake pads, rotors, rear drums and disc brakes
-Rotate tires
-Fuel cap, lines, tank and filler lid inspection
-Clean drums and disc brakes
-Replace air filter
-Replace spark plugs
-Pressure test engine and cooling system
-Drain and fill coolant
-Reset engine specification
-Clean and service throttle body
-Adjust drive belts
-Test thermostatically controlled air cleaner
-Replace brake fluid
-Inspect fron and rear wheel bearing lubricant
-Perform auto/manual transmission service
-Replace fuel filter
-**Replacing timing belt (60,000/90,000 miles)
-**Clean radiator core and A/C condenser (60,000 miles)
-**Inspect spark plug wires (60,000 miles)
-**Adjust ignition timing (60,000 miles)
-**Adjust engine idle speed (60,000 miles)
