MARTINGTI
More trouble!! I changed all my discs a few days ago. Didn't remove the brake lines just tied them up. Today the handbrake light came on and the pedal started to feel soft. Found a leak on nearside rear wheel. Brake fluid pissing out!
Nursed it home and took the wheel off. Fluid was coming out where the pipe joins the calliper. So I took off the brake line and some tit threaded the bolt in wrong. Me moving it around obviously upset it and it began to leak then.
I took off the caliber thinkin the bolt was what was sheared, but no, bolt is fine, it's the calliper that's messed up. U can see in the pic the spring looking metal, that's what was wrapped around the bolt!! From my calliper!
So, can I retread or am I looking at a new calliper??
