I've a question for ye.
I decided to go ahead and retrofit air con in the car. It's not as bad as you might think although i'm not finished yet. Actually, if I had to start from scratch again, it would be handy enough. Having said that, I wouldn't have a clue what i was doing only for Padraic.
Anyway, part of the job is to put a coil in the back of the air vent. I've that done but there was this other thing there, I'm not sure what's its purpose was, but i put it back in when i put in the coil. I find now though that there does not seem to be enough room for both things and the knob that you use to get hot or cold air is gettin a bit stuck when you go over half way to turn it up to heat.
Does anyone know if I need this part or if i can leave it out??
Pictures below. I also put in a picture of the coil fitted just to give an idea of what i'm on about. You can't see the other yoke in there but it is behind it.
