alternator
S
swampdonkey
Guest
i have a bugeye wrx ul type, are all alternators in new age the same? can i get one fro a hawkeye for example
should be more or less the same I think.
As far as I know there where generally two types - with 2 and with 3 pin connector.
In new age I guess all are 3 pins - anyway if you get with connector like yours - that should be fine.
has your car got air-con???
the amp output will be different between a/c and non-a/c....
should be part numbers you can check!!
:thumbsup: :thumbsup:
yeah i have aircon, im hoping i can pick up a 2nd hand low mileage alternator
I have one there that I had recon'd in Myles Balfe over a year ago, Cost me over €100 to get done and got warranty but never installed it.
Its from a classic, but if the pins in the plug are the same it will fit :thumbsup:
