Reckon I'll just have to bring this in somewhere but before I do anything obvious I could be checking? Had a look at the connectors under the seats as that seems to be the most common cause but they aren't loose, disconnected and reconnected they click in fine. Same for the front two sensors by the radiator. ODB tool (Torque app) doesn't show this is a fault as it's not engine related so can't reset. Anything else I could check? If a fuse was gone would the airbag light come on maybe?
