T TommyM Petrolheads Mar 8, 2010 #1 If i was to go for a 2.5 sti engine would my apexi ecu work? my car : 98 Impreza STI Type-R 2.0
H hiwd Guest Mar 8, 2010 #2 AFAIK if you are not changing the heads, you won't have to change the wiring loom or the ECU
S Scoobymaniac Guest Mar 8, 2010 #3 I'm runing a Power FC with my 2.5 V2 Impreza It will work no problem at all
davelegacy Member Number 16 Mar 16, 2010 #5 No Problem at all. ECU is there and available to be mapped to your current mods...
