B4 Fuel Filter
kchawke
Hi lads, anyone know where the fuel filter is on a 00 legacy b4?, I opened the oval panel under the back seat on the passenger side but there was just a fuel level gauge there, thanks.
As above, it's on the drivers side, in the tank with the fuel pump unfortunately. :doh:
Quite a messy job, the container that holds the filter will be full of fuel so be careful when twisting it off.
I found it very awkward to angle the assembly the right way to remove it from the tank too.
See pdf attached below for more info, pics below too.
CLAMP RETAINER - 42037AE110
RETAINER - 42128FC020
GASKET SEAL - 42025AE030
GASKET O RING - 42025AE020
GASKET PUMP - 42025AE000
FILTER ELEMENT - 42072AE000
Nice one lads, sound johnjoe great help, thought i might have the wrong part but got the same as you no gaskets do :thumbsup:
Get these seals if doing filter.
