[quote author=B4 soon link=topic=19371.msg237200#msg237200 date=1258491198]
My primary always boosts to .8
Yours is a REV d, it boosts slightly higher on first turbo[quote author=b4 legacy link=topic=19371.msg237243#msg237243 date=1258497989]
just using 95 oct fuel.was running fine dont think this is problem
i was reading that it could be the wategates sticking .
i had it plugged in on diagnostic and no fault showing.
I would say your experiencing the ecu pulling timing to protect from knock, you can't run a B4 properly on just 95, reset the ecu and as B$ soon says put E5 and some booster in and you will notice the difference striaght away
