geogan
[quote author=KENC link=topic=32519.msg372676#msg372676 date=1323547772]
Its very simple.
The tmic isnt a good cooler so you need to have the air coming in as cool as possible to help it, so a cone filter will only suck in hot air from inside engine bay and is not a good idea with TMIC, Standard airbox will take air from the cooler air from the outside and is a help to the TMIC..
Fmic will cool anything really, so it doesnt matter if you take it from inside engine bay or not, the fmic will cool it just the same, so cone filter is no problem to it... SIMPLES
I see...
Don't the better ones like Typhoon and cosworth have a shield around cone to keep most of the hot air away - with the ram air scoop still blowing huge blast of cold air in still (at speed) from the left side into this enclosed area? And Ireland is so cold anyway most of the time I'm sure the air temp is cool enough - it ain't California!
p.s. the car has heat wrap shielding around exhaust manifold so engine bay doesn't get as hot as OEM manifold.
Its very simple.
I see...
