Altezza-Dan
Need to get rid of all the bits and pieces i have left over from the other legacy i broke. If anyone knows anyone with one of the newer twinscroll legacy or 2003-2008 irish legacy i might have stuff of interested to them. I put an ad up on done deal:
http://www.donedeal.ie/for-sale/carparts/3717412
Standard cat back exhuast( dual exit) - 150
Smoked speedo cluster with 85000kms - 120
Front electric drivers seat(fabric) - 70
Front passenger seat( fabric) - 50
SIde feed injectors (blue 500cc) - 150
Rear Bilstein shocks with springs - 100
Front passenger Bilstein shocks - 50
Aluminium rear trailing arms - 500
Aluminium rear lateral links - 100
Aluminium rear boot lid (minus bottom trim and carpet liner) - 100
Passenger side doors(minus door cards including glass, rear is privacy glass) 50 each
Drivers side windows(rear is privacy glass) 40 each
Drivers airbag - 150
Radiator including fans and overflow coolant tank(same as newage i was told) - 100
Front and rear brake calipers and brackets(painted blue by previous owner discs needed are 316mm front, 290mm rear, larger than irish spec) - 150
Maf sensor - 150
starter motor - 40
Map sensor - 80
O2 sensors - 70 each
Intake manifold - 100
dual avcs heads, one needs some new valves - 400
Also have 2 brand new standard back boxes - 100
HDI GT2 FMIC and CAI kit( only tested fitted never used) - 400
There is probably a few more bits i left out, contact details are in the ad above if anyone is interested.
Maf sensor - 150
starter motor - 40
Map sensor - 80
