on the subject of turbo timers does anyone have this one and if so do they have a manual for it. i know how to set the time and change modes but theres a few other functions that im not sure about http://www.erautobedrijf.nl/webshop/images/apexi_turbotimer.jpg
I bought one from the lads in Pro Parts last week and Find it great! They fitted it and all for around 130 approx!
I find it fine! You can set it yourself for time or it while monitor your rev and adjust time for you! It connect to your hand break so while the car is running if someone was to jump in and let the hand break off it will cut the car out!
Only snag I have with it is the Alarm won't go on while the car is running! but if I'm in a hurry to lock it I just let the hand break off!
This is like an in between harness. And there is a brain box with it that you plug display into. this will all fit neatly with existing wiring around steering coloum......
Then hook up handbrake cut to handbrake wiring. You'll need to remove whole centre armrest console to do this.
the handbrake wiring runs down the drivers sill under the carpet so you dont really have to remove centre console......if ur lazy like me or lookin for shortcuts
[quote author=northdublin link=topic=6739.msg78607#msg78607 date=1208539162]
