[quote author=eliroche link=topic=13258.msg164430#msg164430 date=1236157944]
This is what Godspeed said -
"Yes we have sold the fitting kits to owners of the B4’s , and no one has come back to me saying they didn’t fit so I assume everything is ok , if your car has the 266mm discs , then the 290mm WRX discs and 2 pots should fit fine"
So if standard B4 rear discs are 266mm are all classic shape Impreza 2 pot rear discs 290mm?
i sold impreza brakes to a guy with a b4 and said the rears dont fit because of the space in the bolts, think roby had a similar problem. if you want to be sure you can measure the distance from the center of the two mount bolts, and i'll measure a classic hub here to compare
