Brake caliper rebuild places
Altezza-Dan
Anyone know of any places in Ireland that would refurbish some Ap Racing 4 pot calipers? Im not sure im brave enough to undertake this task myself!
Can get rebuild kit in for them no probs.
You dont have that long and no massive amount of trackdays and heat.
What issues are you having.
Calipers in question are CP6600 model. The main issue is there is build up behind the wear plates and they are getting pushed out resulting in the pads not being able to move freely. I had to file down the back plates lightly and now the pads move to much and clunk. Also I need new discs to go with them too. They are 2 piece godspeed ones so i think i need to keep using them with some new rotor sections. Not a major overhaul. I think they need to be split to get the wear plates sorted so might as well replace the seals and dust boots while apart and repaint them. Anyone have a spare front brake setup for me :)
Can you not just bend the plates?
Some pads are a better fit than others also I noticed dan
i might just order a new set of Ferodos and discs and try that first as i need them anyway. the wear plates are on the caliper body so cant really be bent back, ill probably take them off the car and try again
