Ken OBrien
Hi Dave,
Can I ask your advice on this. Have a 02 bugeye turbo, throwing up fault codes for misfires on cyl 1,2 and 4. But when I disconnect the airflow meter it eliminates the misfires but then obviously you get the airflow meter fault codes. Have replaced the airflow meter with brand new one and also tried another known to be working airflow meter and still no good. Have checked and replaced timing belt and tensioner to eliminate a timing issue, compression test was even across all cylinders. Where do i look at next? Like i say it runs fairly good with airflow meter disconnected but obviously not that good with it getting no reading from airflow or air temp.
Appreciate any opinion you might have, Thanks, Ken.
