Rob Spec C
Scoobymaniac said:I agree that clifford fitting charges are over priced but if you ever fitted one you'd know how much hassle it is, you can spend more than 8 hours doing a clifford alarm. And they are thatcham Cat 1 certified alarms, meaning they are highest rated security. Yes all alarms can be bypassed but with the correct clifford you can't bypass without setting it off first and if its outside your house then you'll hear it.
The way its installed makes all the difference, as i've seen some seriously boched installs by reputable companies![]()
Peter from MDS only took 3 hours to fit mine while i was in bed. That included everything except automatic window winders. I've had no problems with it at all but I assume there would be problems if it was a botched install?
