small minority will want the 97 ron fuel (only us sport car people) so that pretty much put the nail in the coffin for 97ron here![]()
normal people wont pay over the odds for "cleaner" petrol
I had it in the car for the last rolling road day + Nf.
Did you see any difference from before you used it?
You won’t see any noticeable gains in power from higher RON fuel - in fact, in N/A engines you’ll often see a decrease. The higher RON means that it needs a higher temperature and compression to ignite so it is much more resistant to pre-ignition and therefore more stable for turbo applications. Your engine will be much more resistant to detonation with it but not necessarily more powerful. It can be mapped safely for more power due to being more stable but the extra power doesn’t come from the fuel itself
Depends if the mapper has advanced the ignition timing to make use of the higher rating .
Some more clever ecu’s can advance the timing to make use of it so you will see an increase there
Yep, it’s capable of delivering higher power more safely but as mentioned, needs to be mapped for power - many think just running higher RON fuel automatically gives more power. Wasn’t aware of the ECU led advanced timing though - technology rocks!!
