K KudzSTi Petrolheads Mar 26, 2010 #1 Well guys just wondering how you would clean the boost solenoid on a classic impreza, what should I use? cheers, John
wagon dec Member Number 257 Mar 26, 2010 #3 join the plugs under the dash below the steering wheel that puts the ecu in test mode and makes the soleniod operate and then take off the pipes and get some aerosol carburator cleaner and blow it through it that wil sort it
OP OP K KudzSTi Petrolheads Mar 26, 2010 #5 Cheers guys will do that I assume I don't need the engine running just the ignition on with the connectors under the dash joined
