A Aaron Petrolheads Apr 18, 2013 #1 I was thinking of doing it as im not really using the car at the moment. Is it hard to do? Is there a high risk of damaging the headlights? Sent from Note 2
R Rob Spec C Octane Boostaholics Apr 18, 2013 #3 Markokavo only did it recently with his, and its a good job .. I'm sure he'll be on later
Markokavo Well-known member ISDC Club Member Apr 18, 2013 #4 That's the instructions I used. Levelling motors must be covered well with tin foil. Remove all wiring. Light surround quite delicate. Be careful if removing side light reflector if spraying surround.
