[quote author=Dagnut link=topic=32327.msg371095#msg371095 date=1322308813]
[quote author=KENC link=topic=32327.msg371043#msg371043 date=1322250978]
If we forget the serious issue about safety and just think on the fuel consumption, When you down shift through the gears, think what position is your Throttle in??? answer is closed as in the same as tickover.. I would take a guess at having a car/ van lorry etc etc struggling in a gear would be a lot more fuel heavy than down shifting and having the Throttle shut off and engine braking the car
surely knocking it into neutral is the most flue efficient way, not safe but use the least fuel...once the engine is in gear it's doing work
If you are down shifting correctly you are using the engine to brake, its your momentum thats powering your engine not the opposite way around.. so that should mean minimum fuel use.
If you drive any car that has a fuel consumption computer they might not be an exact idea but if you take your foot off throttle going down a hill and let the gearing hold the cars speed and rev.. your computer should read 0 fuel consumption.
All big heavy goods vehicles us an Exhaust brake, which goes hand in hands with down shifting to optimise your slowing down capabilities without burning pads, disk, drums off them.
Ive driven both the 25 and 40 tonne dump trucks and on big road building jobs when you know how to drive the thing correctly the brakesare used very little, only to come to a dead hault, these are all automatic/semi auto so when you let foot off, exhaust brake comes on and it down gears itself , everytime it downs a gear you you have an increased exhaust brake effort.
All this is to minimise wear on wearing parts i.e the brake set up.
As much as i think the show is crap, if you look at ice road truckers you will see from time to time that the safest way and only way really on a steep decent is to pick your low gear that can hold you back going down the hill, if not you will burn off the brakes and worse again is half way down panic, and try to select a lower gear, clutch in and gearings is free from engine to pick up speed and you probably wont be able to re select a lower gear and be lucky to get back in gear at all.
For a while there was loads of Dumper trucks accidents, a lot of these were down to guys knocking them into neutral going down hill to get more speed, prtoblem was when they did this they forgot to keep revs up, so when they went to go steer the thing the steering was next to zero and sometimes konked the engine out on tick over..
So i wouldnt like to have to steer in an emergency when having the van struggling in 4th like this guy has advised
