drivers door wont lock
L
legmangt
Guest
i got my 98 legacy two weeks ago and already im having problems!!!!! :icon_cry: :icon_cry: after the second day i found the drivers side brake caliper was seized.... and now the drivers door wont lock.. not even with the key the button is stuck in the open position... inly get to drive at the weekends so dont have much time to mess around with it...dont want to bring it to a garage either especially after how much i got charged for the caliper and labour.... :wall: :wall: :wall: :wall: pls help lads... first time subaru owner.
:thumbsup: cheers bud will do. but sat inside and tried closing it from inside and the button is jammed.. how can i get pics of the car up
:subaru:
Take of the door card and have a look at he plastic huks and steel rods that control the mechanisim. See if they are all where they should be. Might have worked loose and have jammed it.
:smile: good man ill do it over the weekend.... cheers for the advice
:icon_sad: nah.. he was a p :angry1:k.. i traded my fwd twin cam and cash for it... deal was done way to quick... soon as seen it i wanted it :hammerhead:
i had something similar happen to mine. the drivers door barrel became loose and jammed up the little rod that goes from the handle to the mechanism. take off the door card and remove the plastic crap and have a look. i had to loosen some of the bolts for the window mech but dont take them out completely as some of them are a bastad to get back in
