Just came across this.
http://www.evoscan.com/technical-vehicle-manuals/148-subaru-diagnostics
IntroductionYou may want to reset your ECU because you want to clear a fault code or simply to let you ECU re-learn your settings again, say after a modification or change in fuel (octane).
In summary classic Impreza’s can be manually reset and new age Impreza’s onwards have to reset using a tool plugged in to the diagnostics port.
New Age (Denso) ECU ResetThe Denso ECU’s don’t have a manual reset function like the JECS ones.
The Denso units apparently have a non-volatile RAM, so even disconnecting the battery won’t do it. The only way to reset these ECUs is via the OBDII diagnostics port using a computer. Until recently this has only possible at the main dealer or using other commercial solutions e.g. Delta Dash or SECS.
What follows is a description of resetting your Newage ECU using ecuExplorer
1.Download and install the latest release of ecuExplorer
2.Connect up to the OBDII diagnostics port with reference to the connecting to your ECU technical article.
3.Turn on your ignition
4.Invoke ecuExplorer and select the Tools → Reset ECU option as illustrated in the figure below.
5.To complete the reset, turn your ignition off, back on, then start your car.
