Hello ladies and gents , aint realy been on much the past 6 months , mainly jus popping in and out to keep an eye on you's . hope all keeping well
So last year with the club we did the ring trip and as usual , it was epic . i had a few issue's and mainly with the help of joe , baz and dave (hope i havnt forgot anyone but possible) we made it across europe and back .
when back in IRL she was parked up and not seen much use bar weekly start and 2 min spin . a list was made of niggles/fixes that needed to be given attention , some small some not so small . but like all good intentions, life kinda got in the way and the list wasnt really looked at . jus kept the weekly spin to keep the cogs turning .
so now Janurary ,new year, new start .... plus nct due is in the post so have to get the finger out and tip away at list to get it back to where it was .
first job - passo dip light not working .
so iv had this issue for quite a while, started off with bulb turnig itself off sometimes ,after turning lights on . fix for a while was turn off lights at stalk and turn them back on ,bulb worked fine . this issue got progressivly worse as off/on trick stopped working . thinking it was more bulb related .got a new one installed by dave, but on collection bulb was not light as it was 5min b4 upon check by dave . so after a quick fettle , it was discovered it was blowing fuse as soon lights turned on at stalk . Being close to lift off dave had another look but couldnt find issue, i swapped stalk from mates bug but no joy there either , so went to germany and only drove during daylight as to avoid any hassle .
hopefully when i get this fixed , a simple exhaust swap should get through nct and then onto rest of THE LIST .
so here i am looking for someone to help get this issue sorted . any help appriciated .
