might aswell do the timing belt since its all coming off anyway, you can get a kit from ICP for fairly cheap with same bearing etc as in subaru kits. Are you going to build it a bit stronger? I would do minimum sti rods and pistons while its apart. hone and skim the block pressure check heads etc, its hard to know when/where to stop "ah sure while the engines out"!
