Scoobyturbo
Well after getting my airbag light fixed and a new rear wheel arch it got tested tonight and Failed on few simple bits well chuffed i have to say.was expecting much worse.
Rear tyres near/offside failed
Rear axle and wishbone bushes near/offside failed
Break pedal rubber failed
Emissions are ok although i dont understand it are below results good?
Oil temp 89*C
Low idle
750 rpm CO 0.19 vol% pass (limit 0.50%)
HC 87 ppm N/A
High idle. Lamdba:1.00 pass (limit between 0.97 and 1.03)
2960 rpm CO 0.27 vol% Pass (limit 0.30%)
HC 29 ppm pass (limit 200ppm)
Cant belive il have an nct disc in the next 2 weeks
Oil temp 89*C
Low idle
HC 87 ppm N/A
