flash coding and oil levals please
T
traymcs14
Guest
hi lads i have a 94 wrx jdm can someone tell me how much engine oil goes into it and where is the vechile speed sensor in it to a flash coded it but dont know wrere it is nct tuesday morning :icon_sad: :icon_sad: :icon_sad:
Speed sensor on the gearbox could be broken.
Have you had the dash clocks out recently? Maybe the speedo cable wasnt plugged back in fully?
took out the clocks speedo cable was attached. where exactly is the sensor in the gearbox? there is two i take it that ones the reversing sensor and the other is the vechicle speed sensor am i right with that.
If you look down past the turbo you will see the speed sensor on the right hand side of the gear box
Well mine is a 99 and thats where mine is hope this helps :thumbsup:
thanks keith ya had look at them look ok but is there any way of testings them lads nct in the morning :icon_sad: :icon_sad: :icon_sad: :icon_sad:
